Guest viewing is limited
Discuss Fitting shower waste - no tray in the UK Tiling Forum area at TilersForums.com.
misterneil
Excuse the lack of expertise - I'm a plumbing virgin!
I'm currently building an open shower in the corner of a largish bathroom. The floor is concrete on brick supported by reinforced concrete beams above a cellar (this is in Spain by the way) I plan to make the floor to a fall using cement sealed with 'gaucho' - a thick paint-on rubber membrane. This will then be tiled probably with small tiles on mesh. My question is what type of trap is best for this and how is it best fitted?
(At present the 'floor' of the shower area is 80mm below the level of the tiled floor of the rest of the bathroom the area is 140 x 85cm - see photo).
Thanks for your help, cheers, NeilC
Reply to Fitting shower waste - no tray in the UK Tiling Forum area at TilersForums.com
  • Sticky
Hi folks, I have been doing a lot of research as to which is the best tanking product to use on...
7K
Bit of an intro - I'm a competent DIYer and have been refurbing the bathroom on and off for the...
6K
L
As per the title, I have a 1170 recess and the customer wants me to replace the shower and...
8K
Rizzle from the Portizzle
