Discuss Fixing external tiles to rendered wall in the Australia Tiling Forum area at TilersForums.com.
Gerry1
Hi, would anyone be able to advise me on fitting exterior tiles. They are ledge stone split face mosaic tiles. I am going to fit them to an outside wall which is brick and currently rendered and painted with stone paint. Do I need to hack off the render and fix to the brick after sealing them or can I fix directly onto the painted render? Also which type of adhesive should I use? Many thanks. Gerry
Dougs Third Go
Thanks for the advice and the Mickey taking. its only a small feature wall and not the poxy cladding you see on some houses. Back to the advice part---- What would the best adhesive be? Would it be a cement based type?
yes Gerry, make sure it's flexible, personally I'd go for a S2 type adhesive.
Reply to Fixing external tiles to rendered wall in the Australia Tiling Forum area at TilersForums.com
Hi, I have a very small area (1m.sq) on an exterior doorway entrance wall to tile. I would...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hello, I have some lovely Mexican terracotta tiles (glazed on one side only) which are meant...
    Votes: 9 6.2%
    Votes: 13 9.0%
    Votes: 10 6.9%
    Votes: 44 30.3%
    Votes: 17 11.7%
    Votes: 34 23.4%
    Votes: 3 2.1%
    Votes: 20 13.8%
    Votes: 18 12.4%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
    Votes: 4 2.8%
