Discuss Fixing Glass Shower Screen to wet room floor method? in the Tanking and Wetrooms area at TilersForums.com.
Chalker
1,058
Tadcaster
If you use a kudos wet room screen. They have a 2mm thick strip of plastic, bonded to the bottom.
I mark the floor, masking tape round where the screen touches the floor.
Then lay a bead of Silicon on the floor and fit the glass on to it.
Clean off the excess and when dry go round with clear Silicon.
Blunt Tool
I do same as Chalker with any screen make! do the fix to wall mark where glass going to sit on floor place couple of small wedges between floor and glass, bed in with clear Silicon and seal all round with wedges in place, once dry wedges out and fill gap left with the Silicon.
Q
Qwerty
I've used these for years. Absolute godsend!..... Transparent Plastic setting and Distance Blocks - https://www.wholesaleglasscompany.co.uk/acatalog/Transparent-Plastic-setting-and-Distance-Blocks.html
Hi there! I'm just at the final stages of my wet room installation, and I'm going to be placing the wet room glass onto a piece of Quatz on top of a small shower curb (10cm wide). Ideally, I'd like the glass to just sit on this with no visible fixings.
Just to be clear, are you saying I could get away with a recessed wall channel, and then ONLY Silicon on the bottom (and possible ceiling edge), separated by some spacers, and no other physical fixing (e.g. clamp or channel) along the bottom edge?
If someone leans on the glass will the Silicon hold?
Or have I got the wrong end of the stick?
Reply to Fixing Glass Shower Screen to wet room floor method? in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
Shower Tile Repair - Tile Waterproofing in Brownstown MI. Schluter wet room conversion 24h...
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
  • Sticky
Bristol
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
