Discuss Fixing tiles flush with the wall in the Canada Tile Advice area at TilersForums.com.
DJM
I am updating the downstairs toilet and have discovered the original 1920's floor tiles below the carpet are in not bad condition and we want to keep them. The need a little TLC and I asked about that in another thread. But, to keep the theme I have bought some matt black/white chequer mosaic tile to use as the basin splashback and run a border around the room.
I had a mad idea that it would be a good idea to make this border flush with the plaster which means removing a channel of plaster back to brick. Now the issue is that means the depth brick to plaster would be about 20mm. As the mosaic tiles are very thin that would seem a far too large adhesive bed (and be expensive).
So I was thinking of laying a cement screed or plaster skim of about 10mm to leave an adhesive bed of approx 10mm
So is the idea mad, is there a better way of doing it, or should I forget it and live with the raised tiles around the room?
Reply to Fixing tiles flush with the wall in the Canada Tile Advice area at TilersForums.com
Hi, so I’m relatively new to tiling. I’ve got a job where the walls aren’t 100% flat but not the...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
