bob345
Bit unusual one. I am trying to line the base of 4 chimney alcoves with timber panel prior to plastering. The end effect being a plastered alcove with a timber 'floor' protruding from the wall like a windowboard. My question is what to use to fix the timber panel down - the substrate is masonry, and not level, so the thickness of bed required will be between 5 - 25mm. If the bed didn't need to be so thick I would probably just gripfill down. Perhaps a tile adhesive would be the way, but would it bond to the timber? or should I just fix onto a sand/cement bed, and screw down when this has cured. The timber panel has been painted on all sides so any moisture doesn't affect it. Cheers for any help...
