Discuss Fixings for marmox in the UK Tiling Forum area at TilersForums.com.
dylan_30
Hi all,
Just a quick question as my bathroom job is well underway now and by next weekend I should be ready to start bringing in bathroom furniture etc....
anyway what I wanted to know is what fixings would be suitable for marmox board. I want to screw items into it at various locations however I have used marmox on floor and wondering what fixings for the likes of toilet etc..
I have tried researching this myself but only get fixings for marmox installation.
thanks for any info
dylan
davemul
Is it an upstairs bathroom? if so the floor should be some form of plywood underneath the marmox (marmox fixed with cement based flex adhesive & marmox washers and screws)
so using normal screws to fix the toiled basin will be fine (as long you check for pipes under the ply)
I would tile the whole floor first then drill holes for toilet basin so it sits on the tile surface, no need for niggly tile cutting then
davemul
In that case then I would drill, plug and screw the basin down. The plug must go in to the concrete and screws must be long enough to penetrate through the marmox in to the plugs. Screwing in to Marmox alone will not be good enough as it is essentially just polystyrene foam with a coating of glass fibre/ polymer-cement mortar. :thumbsup:
Reply to Fixings for marmox in the UK Tiling Forum area at TilersForums.com
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
I would very much appreciate the advice of anyone who has fitted Marmox boards as I have decided...
6K
I had some advice here a while back on laying Porcelain Tiles on Outside porch , I followed...
What are electric cleaning brushes? . Powered by electricity, it can scrub anywhere in your...
Good afternoon all. I am a keen DIYer (at home) but have never tiled! I want to tile our small...
Fixings for marmox
    Votes: 6 4.6%
    Votes: 11 8.5%
    Votes: 8 6.2%
    Votes: 37 28.5%
    Votes: 16 12.3%
    Votes: 31 23.8%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.6%
    Votes: 18 13.8%
    Votes: 15 11.5%
    Votes: 7 5.4%
    Votes: 3 2.3%
    Votes: 2 1.5%
