Hi all,
not sure if this is really the right place for this, but here goes...
I'm renovating a small (75m²) cottage. I installed underfloor heating and the concrete slab wa poured over a year ago, so I'm guessing it's good and dry at this stage
I'd like to finish it with a flagstone floor, but my plumber is a little worried about the heat penetrating through the thickness of the flags...while he's installed plenty of ufh systems, he has no experience in dealing with flagstones so I think he's being overly cautious...but I'd really like some more opinions on this.
The first flagstones I'm looking at are Indian limestone calibrated to 20mm.
I also however have the option of locally sourced slate flags, but these vary in thickness from about 20mm to 40mm. These would be irregular shaped, but I could work them a little and the cottage is extremely 'rustic' anyway so I would be happy to use these.
The second option would be my preferred choice...I would love to get them locally, plus I like the random look of them...and also the price is definitely right! (tight budget!) but there are 2 issues I'm worried about with these flags:
1. If the plumber is worried about the 20mm...I'm afraid he'd freak completely if I mentioned the 40mm
2. If the flags are of varying thickness, I'm assuming I would have to garde them to keep things level-ish? would this affect the heating?
So, I guess my question are:
Is there any limit on the thickness/depth of Flags that can be used? (I realise responsiveness becomes an issue the thicker you go)
and
Is there any problem with flags of varying thickness?
and
