Discuss flexible adhesive in the British & UK Tiling Forum area at TilersForums.com.
kilty55
1,113
edinburgh
hi all,i thought you didnt need to use a flexible adhesive when putting ceramics onto a concrete floor only when using porcelain,,was told today by a tiler on the job i should be using flexi?? is this correct? bit confused now:whatchutalkingabout also whilst im on the subject what is the actual difference between a 1 part and a 2 part flexible adhesive? havent actually use a 2 part flexi yet ,cheers:thumbsup:
robbo
BAL Fastflex Powder & Liquid
A two part, rapid-setting, sulphate-resistant, water-resistant and frost-resistant floor tile adhesive and isolating, anti-fracture underlay, suitable for use in interior and exterior locations. Suitable for fixing ceramic floor and porcelain tiles and mosaics (including fully vitrified), dark natural stone and slate. Suitable for use on tile backer boards, glazed tiles, concrete bases, cement:sand screeds, tongue & groove floorboarding, plywood overlay, floating plywood/chipboard floors, ceramic/quarry tile/terrazzo/hard natural stone bases, vinyl tiles/sheet, mastic asphalt, steel, glass reinforced polyester (GRP), steel and galvanised steel. Conforms to BS EN 12004, Type C, Class 1F
BAL Single Part Flexible
A flexible, non-slip, water-resistant and frost-resistant wall and floor tile adhesive, especially suitable for fixing tiles, including fully vitirfied and porcelain tiles to low porosity backgrounds/bases. Suitable for use on concrete/brick/block walling, cement:sand rendering, plaster, plasterboard, cement sheets, tile backer boards, concrete bases, cement:sand screeds, plywood overlay, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet bases, mastic asphalt. Conforms to BS EN 12004, Type C, Class 2T.
grumpygrouter
I don't think flexi is necessary on concrete but if it was heated I would go flexi.
Bal Rapidset, Goldstar and CTF3 are all ok for concrete according to te BAL Bible!
mickbull
I would only use flexy if there was a heating mat! Normal rapidset is fine for concrete, both bal and mapei state there rapidset is suitable for porcelain!!
Reply to flexible adhesive in the British & UK Tiling Forum area at TilersForums.com
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
I have recently laid around 30msq of porcelain floor tiles in our kitchen. The tiles have been...
kilty55
edinburgh
flexible adhesive
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
