Discuss Floating Floor and Tiles mix? in the British & UK Tiling Forum area at TilersForums.com.
Hi all,
Been asked to lay tile on a floating floor thats made up of 3x2 joists sitting on top of a concrete floor and has 18mm ply screwed into the joists.. Is this do-able on this floor type as ive never experienced tiling on a floor of this construction?
The floor also has a slight bounce where 2 sheets of ply meet however I think this could be overcome by either lifting the ply and laying a new whole sheet as room is only 2.5m2 or laying new ply say 12mm ontop of current 18mm ply but am open as always to suggestions?
Thanks :smilewinkgrin:
Time's Ran Out
You obviously have reservations about tiling on it!
You will no doubt be advised never to tile on a floating floor.
Some adhesive manufacturers state that their products are suitable for tiling onto floating floors - but they always put the onus back on the tiler to make the substrate deflection free.
Its your call!
DHTiling
If it has a frame work then it isn't classed as a floating floor in some aspects but if the frame isn't fixed then this is where movement could happen but you shouldn't get as much movement as you would with a floor just onto insulation like the majority of floating floors are.
The movement you have could just be a joint with no support, so worth checking before you tile and probs will need over boarding for extra stability.
mikethetile
strictly speaking this isnt a floating floor construction
its one type of warm floor construction where the flooring is fixed to battens fixed to the floor with insulation batts between the battens, this is not a floating floor but often gets called such
the other type of warm floor construction is where the floor is floated independantly on a subbase of insulation, this floor causes problems with tiling as the extra weight may compress the insulation over time
Reply to Floating Floor and Tiles mix? in the British & UK Tiling Forum area at TilersForums.com
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
Scotland
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
