ARC123
Hi.
I've discovered I'm the not too lucky owner of a Floating Floor, 18mm chipboard on 25mm insulation, supported by concrete "block and beam" I'm having a new kitchen and when the old tiled floor came up (slate on 18mm chip ply) we found the dreaded floating floor below. The old floor had flex in several places and some tiles were loose or cracked. All the advice I've seen so far is "Don't tile on it" ! So it's coming up and I need to replace it with something which will take 450mmx450mm ceramic tiles and last as long as I do. Going for alternative surfacing us not an option as I want the tiles to match those in an adjacent conservatory and they were bought on special order. The Difference in Levels between the rooms is not a problem as there are steps between the two.
Question is what to put down instead? I need to make a decision ASAP. All advice from those who have experience of this most welcome.
Andy
Andy
