Discuss Floating floor to concrete in the Canada Tile Advice area at TilersForums.com.
d.bott
Need some advice please,
We have just knocked down kitchen wall to open up through dining room.We will be tiling throughout.The problem is that the dining floor is a floating floor,chipboard on insulation and the kitchen floor is concrete.The concrete floor is 10mm lower than the floating floor,what would be best to raise the kitchen floor and then bridge the joint of the two floors.The tiles are 600x600 porcelain
Ajax123
1,213
Lincolnshire
Thanks for advice,
The tiler is thinking of using ply over floating floor,is this a good idea?
Is there any other options apart from re screeding
Not if you want it to last...
I think the advice is to not tile the floating floor.
Lots of previous threads on the subject on here. No doubt you've had a browse..
Do we have any sizes??
is it just a couple of m2 and you're prepared to take the risk? or is it a 50m jobby that would obviously be very costly when it fails.
Putting ply on top of a floating floor means its still a floating floor, with ply on it.
Reply to Floating floor to concrete in the Canada Tile Advice area at TilersForums.com
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
