Discuss Floating floor in the Canada Tile Advice area at TilersForums.com.
2020Tiling
Hi Guys! Have a floor too tile and it's a floating floor but seems solid, Is there any way of knowing if it's going too fail or not? And do you advise a 2 part flexi? I'm just getting loads of floaters and up until now I have walked away, But I am loosing too much business because of this. What do you lot do regarding a floating floor? I'd really appreciate any advice thanks! :thumbsup: Tiles are Ceramic.
prceramics
ask yourself if you would be prepared to put it right out of your own pocket if it goes wrong baring in mind that if a customer signs a disclaimer it will not hold up in court, you as the tiler are accepting that the substrate is suitable for tiling by tiling on it ! if you are prepared to take that gamble good luck to you my friend :)
John Benton
1,138
Leeds
Yes Fitting laminate when she gets it
I've turned away work on this substrate, you look at risk assessment and weigh up if it's worth doing the job.
Just remember this - It's highly unlikely that the laminate floor will cause you need to go back at your own expense to repair.
Sleep easy!!! :thumbsup:
Reply to Floating floor in the Canada Tile Advice area at TilersForums.com
hello Folks, its a tiny area. 1.8 m2. Joists are solid 3 inch wide. Area is upstairs close to...
Floating floor
    Votes: 6 4.6%
    Votes: 11 8.4%
    Votes: 8 6.1%
    Votes: 37 28.2%
    Votes: 16 12.2%
    Votes: 32 24.4%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.5%
    Votes: 18 13.7%
    Votes: 15 11.5%
    Votes: 7 5.3%
    Votes: 3 2.3%
    Votes: 2 1.5%
