Discuss floor formers.....how much? in the Canada Tile Advice area at TilersForums.com.
JDX
Thank you for the reply Dave, I will spend a bit more time looking...haven't found the right thing yet, have looked at PHG & Tilefix & also Impey (huge prices), marmox, Topps, Kaskade, maxxus, Schluter, aquafix & others over the last couple of days. I am trying to avoid diagonal cuts in the tiles, prefering a minimalistic look - have built the stud walls either side & the rear of the wetroom is an external wall, so the waste can go straight out into the stack easily, so I want a linear full width 1200 waste which can butt up against the external wall, any suggestions greatly appreciated. I'm now thinking, maybe I could make something myself with a slope to the drain...do you professional guys ever do that?
Just had a couple of bad shower formers from the Bathstore the lip on the drain edge was not deep enough it was only about 5mm high and had a long slimline center tray which was tiled this was even lower than the outside trim so when it was tiled left a raw cut edge all the way round the drain the plumber fitted them so just had to tile them it did not look good.
Reply to floor formers.....how much? in the Canada Tile Advice area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
Does anyone have a DIY link or suggestions for removing just a single central tile from a...
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
Tilers Forums on FB
