Discuss Floor prep & standard set adhesive advice for a novice please! in the Australia Tiling Forum area at TilersForums.com.
Dickyparsnips
Hi,
I have the following scenario & would be most grateful for any advise on this;
Kitchen floor in a new build house (11 yrs old) screed covered in an asphalt / bitumen (black shiny finish). Fairly level, no delamination or breaking up etc... (approx 30m2 hence standard not rapid set)!
Looking to lay slate floor tiles.
Can I directly apply a standard set adhesive to the floor without pre preparing the surface? Or do I need to
key the surface & / or bond / prime the surface prior to applying the adhesive & tiling?
Also what's your opinion on the best value for money standard set adhesives?
Your advice is much appreciated.
Thanks in advance.
Mark@Tilemaster
NOT VALID
129
283
Leyland
Give the asphalt a good/thorough clean. Prime with a slurry coat primer, if using our Primeplus, making the slurry is very straight forward and instructions are on the packaging.
In regards to adhesive, of course i am going to be biased and i would recommend using our Standard Set Setaflex. Price wise, as a brand we are generally very competitively priced and we have independent stockists nationally :thumbsup:
Reply to Floor prep & standard set adhesive advice for a novice please! in the Australia Tiling Forum area at TilersForums.com
After some advice please..... We have approx. 50sq m of Dijon limestone 600 x 90 x15mm and also...
Hi all, We've installed a breathable limecrete floor with wet UFH in order to manage problems...
10K
Hi everyone, I'm getting towards the end of a major renovation that has taken 4+ years so don't...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
