Discuss Floor prep in the Canada Tile Advice area at TilersForums.com.
ajc
Quick question for a general consensus please:
I'm tiling a floor soon that is 18mm tongue and groove floorboards, overlaid with 18mm floorboards!!! God only knows why this is the case. The 2 layers of boards are not perpendicular, but the joins are staggered so they are not directly above/beneath each other.
It seems absolutely rock solid (as you'd expect!) but what would people do here? Top layer is highly varnished?
Cheers
White Room
The floor plate of the stud wall should be either screwed or nailed into the joists, you would need to cut the overlay floor boards flush with the wall, as Julian hardie glued and screwed but I would keep the boards tight where the overlay floor boards had been cut.
Avoids any possible movement from the stud work.
Reply to Floor prep in the Canada Tile Advice area at TilersForums.com
Hi guys, I'm new to tiling and looking for some advice. I'm practical and usually pretty good...
I am going to be tiling my upstairs bathroom that has a wooden floor. It originally had wooden...
5K
Floor prep
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
