Discuss Floor preparation in the Australia Tiling Forum area at TilersForums.com.
Wood's better
Hi,
I have ripped up a softwood tongue and groove floor, fitted noggins & 22 mm tongue & groove plywood read for UFH and 600 x 600 porcelain. (bathroom)
I propose to lay 6 mm tile backer boards. I have used Marmox before successfully, however, think Hardi is tougher and tightens the floor better (I know its only for the tiling surface, but I think it definitely makes it stiffer.
Please could I be advised: When using 6 mm glued and screwed down is there really benefit in the foam insulation boards over Hardibacker or No More Ply. If it were say 20 mm thick I am sure it would make a difference to the UFH,
I would appreciate your help.
Many thanks
Richard.
Reply to Floor preparation in the Australia Tiling Forum area at TilersForums.com
As an introduction, I'm a DIY home owner who has gutted the bathroom in a house built in 1980...
Tony R
Hello. I have a couple of questions, recently I went back to tiling x has been a lot of years...
Hello all, I am planning on tiling my bathroom floor, I removed the old tiles myself which were...
Installing tiles 400x600 over an exposed exterior cement screed - it has 20mm fall over 2300mm...
Tilers Forums on FB
