Can anbody advise if they have used the Instalay product from Instafloor which is a self-adhesive underlay that can also act as a uncoupling membrane and they say removes the need for wet adhesives. It's 2.5mm thick, thermal conductivity 0.043 m2K/W, so just under half a tog and compresses by around 8% (0.2 mm)
I have several area's (85m2) to install 4.7kg(24kg/m2) 10mm porcelain tiles on. The substrate is a Gypsum Calcium screed with underfloor heating that was installed several years ago.
The other option is to prime the floor and use something like Tilemaster Anhyfix.
Preference is to use something other than adhesive if possible.
