Discuss floor tiles and marley floor tiles? in the Best Floor Tiles area at TilersForums.com.
Hi mate,If the marleys are well stuck down,clean the floor with sugar soap,Then use a flexy addy,think when i did one i used a Dunlop spf.hi all just wondered what the best way is to lay floor tiles on top of marley floor tiles thanks.
hi buddy i had marley tiles on my kitchen floor before i tiled it i used my 'big mutt' and got rid of the pesky things :santa_cheesy:
You must remove the marley tiles. then the belt an brace way is to give the floor a good clean and put a slurry prime. A slurry prime should consist of 1 part adhasive, 1 part water and 1 part acrylic primer. mix it all together, apply to floor and allow to dry. then fix your tiles as normal.
I hope this helps.
I have just removed some vinyl floor tiles and been left with acrid smelling bitumen (I assume) adhesive. The tile shop guy (I've read the comments about their advice!) told me it would take ages to remove and it was ok to simply tile over the top.When you remove the tiles, you'll need to remove the bitumen too.
Reply to floor tiles and marley floor tiles? in the Best Floor Tiles area at TilersForums.com
