Discuss Floor tiles in cloak room in the Best Floor Tiles area at TilersForums.com.
Waluigi
Also the reason Ply is rarely considered acceptable is because of the veneer. It’s far too thin in most ply wood and the glue used in the bonding process isn’t good enough to stop the ply from easily delaminating. There are a few exceptions to this- SP101, FG1 and Some Marine Ply however Ply isn’t necessarily a particularly stable product in humid environments and some of these ply wood products I mentioned above are very expensive therefore most tilers opt for a tile backer board, Hardiebacker being the most popular however I prefer using a silica free board like Orbrey Pro Ply.
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
Orbry Pro Ply is a water resistant construction board that is suitable for use with tiles, paint, wallpaper & plaster. The 1200x800mm boards are available in 6mm or 12mm thicknesses and can be used internally and externally. Made using a low CO2 method, Orbry Pro Ply boards are also free from silica and asbestos and are not affected by changes in temperatures - perfect if using with underfloor heating systems.
Features & Benefits:
  • 1200x800mm; 6mm or 12mm thick
  • Strong
  • Lightweight
  • Impact resistant
  • Environmentally friendly
  • Non-flammable
  • Asbestos & silica free
  • Mould resistant
  • Internal & external use
6mm thick boards can be used to strengthen an existing timber floor in place of 15-18mm WBP plywood, while the 12mm boards replace plasterboard on walls & ceilings internally. The boards are water resistant but will need tanking if used in wet areas. Each board has a rough and smooth side - the smooth side should be fixed to the floor/wall with the rough side facing outwards.
Please note Orbry Pro Ply boards will be delivered on a pallet.
  • Strong
  • Lightweight
  • Impact resistant
  • Non-flammable
  • Mould resistant
Orbry Pro Ply Hard Tile Backer Board - https://www.tilefixdirect.com/product/Orbry-Pro-Ply-Board
Tile Fix Direct
TF Official Sponsor
153
743
Aldershot
Reply to Floor tiles in cloak room in the Best Floor Tiles area at TilersForums.com
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
