Discuss Floor Tiles Meet Wall Tiles in the Best Floor Tiles area at TilersForums.com.
U
uncleg
Hi all,
First time poster here!
I had my bathroom and ensuite tiled in the summer, but where the wall tiles meet the floor tiles, previosuly it looks like the gap was simply grouted. Now it is craking in certain places.
He is omcing back to look at at it and I wanted to know what the options are, he suggested a skirting which would look naff, or some type of trim?
I reckon it should all be removed and done again..... Please can you guys help in suggesting what would be suitable and practical, as searching on trims, they tend to need to go behind the tile...
Many Thanks All
Gazzer
Thanks Doug.
Would you then grout over the silicon bead, or just leave it? Apologies if its an obvious question!!
Thanks again!
What you need to be telling this "tiler" is that you want the cracked grout removed and replaced with a Silicon sealant to your colour choice. If he regrouts then it will crack again. Do not grout over it, it wont stick anyway.
Stan001
uncleg - the Silicon you need will have 'bathroom spec' or 'anti black mould' or something like that written on them. they cost a few pounds more than a normal white low modulus Silicon (that stuffs only good for sticking double glazed windows in). Each 310ml tube will cover about 8metres linear edge, so you probably only need a couple of tubes.
Reply to Floor Tiles Meet Wall Tiles in the Best Floor Tiles area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hi, 1st time tiling, decided our ensuite would benefit from being a wetroom. Quick question, any...
Tiling my en-suite was part of a larger build project. The builder subcontracted the tiler who...
Best Floor Tiles
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
