wilmslowwhite
I'm a enthusiastic DIYer. I've knocked through a cupboard to make an ensuite bigger (its now about 3m2); removed a cast iron bath; put in new shower; extra basin, moved wc and tiled the walls with large tiles (1000mm x 333mm and 592mm x 333mm). Done everything myself apart from plastering one wall and I'm really pleased with the job so far. Had some great advice from the forum along the way.
I'm in to the last part of the job, tiling the floor.
The floors were tongue and groove boards. After I had laid new pipework most of the boards were ok so I put them back down, screwing wherever I could. I know you guys wouldn't have done what I did next but I was concerned about the height of the floor and was partly going from a DIY book - I laid down 6mm ply. I nailed it down every 100mm and then I've tanked the room with BASF Lastogum.
The floor seems ok to me, their is a small area where there is a bit of movement when you stand and transfer weight from side to side but I don't think its so major.
I could do with your advise on the following:
1. For the floor tiles I was going to lay down a thick bed of adhesive (12mm), thinking that this will give a bit more support/firmness for the tiles - will this help or has anyone got any better ideas?
2. Any advice on the best adhesive for this job? I used a Bal Flexible Single part for the large tiles and was going to use this again for the floor.
3. Will it make any difference if I use larger or smaller spacing for the grout?
4. Any other tips for making the job stronger/firmer?
All advice will be greatly appreciated.
Thanks fellows.
Thanks fellows.
