Discuss Floor tiling problems in the UK Tiling Forum area at TilersForums.com.
stevie25
Hi
Went to see a job the other day, 60m2 timber floor which has been tiled about 1 yr ago . In areas there is cracks in grout etc which I put down to movement , it's an extension and ah told me she's had the builders back To repair areas that were bad tiles popped cracking etc. I lifted couple tiles there's piped underfloor heating under the ply but also the builder hasn't used a subfloor he's plyd rite onto joists 18mm ply.were I think this is a part of the problem . I haven't done a floor with the heating Pipes just the mats etc . Do u need to use a matting or other coverings when installing tiles onto ply when ufh piPes are used ??
Any feedback would be much appreciated
Stevie25
Time's Ran Out
The preparation of the sub floor is all wrong. 18mm plywood direct to the joists and tiled straight on just asking for tiles to crack. If its deflection free it should still be over boarded with a hardie tile backer board as a minimum before any tiles are fixed. What insulation has been used and how are the pipes supported.
Reply to Floor tiling problems in the UK Tiling Forum area at TilersForums.com
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
