Discuss foil backed ufh in the Canada Tile Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
Foil backed insulation boards I assume. If it is something like celotex or kings pan it will be completely unsuitable for tiling directly to as the alkalis in the wet adhesive or levelling compound will react with the alluminium to evolve hydrogen gas which will destroy the bond with the foil.
if it is something else then not sure...
Ajax123
1,213
Lincolnshire
cheers guys no not the foil backed boards its the roll of foil with ufh wires attached its for carpets and laminates normally i told him it wasnt for tiling just wondered if there was some product out there that i hadnt seen
Again I agree with you. I think I do know the product. It is quite flat and an be used under laminate flooring as well... I deffo can't see it being suitable for tiling onto. It would be a bit like tiling onto a sheet of polythene.
I assume this product would come per printed with "tiling disaster" cos that's what it sounds like it should have written all over it.
Bubblecraft
The foil UFH out there is only suitable for laminate & carpets. If it were to be tiled on, there would be no contact with the substrate at all. Even fitting a floating floor on top would fail as again, there is no contact being made between the substrate & floating floor. Loose wire or matting are the only electric UFH systems available to be tiled on whether tiled on top or in a screed
Reply to foil backed ufh in the Canada Tile Advice area at TilersForums.com
I’m nearly there with a bathroom tiling Project and managed to make it this far before getting...
Hi all, I will soon be installing the Wunda EPS 400 UFH boards in my own kitchen, approx 50m2...
Dear all, First time poster here and would like you r kind suggetion. I am getting a builder...
kilty55
edinburgh
foil backed ufh
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
