Discuss Forget the Wet Sponge Idea in the Canada Tile Advice area at TilersForums.com.
Filip
498
Midlands
I have come up with a DIY constant water supply with a pressure sprayer / pipe and a 1ml syringe with the finger end cut off and a blunt needle. The flow of the water is controlled by the position of the elastic band,I just roll it further down putting more pressure on the trigger. I will either fix it to the tile to be cut and aim at the blade or attach to the grinder and point at the blade from there making sure that it is very secure of course. I can use an even finer needle for a thinner and longer water jet so I can keep it well away from the blade
Deleted member 49260
Water injected into vein = dead I think ?
You're thinking of air aren't you? Classic TV cause of death. I saw a chemo transfusion alarm monitoring for bubbles but ignore what I'd call big ones - I even double checked and nurse said little bubbles like that are fine, wasn't my arm they were going into so it was fine
Reply to Forget the Wet Sponge Idea in the Canada Tile Advice area at TilersForums.com
Midlands
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
