Discuss Gap between tiles and ceiling in the bathroom in the Bathroom Tiling Advice area at TilersForums.com.
tashy32
Afternoon
Apologies if this thread has already been posted.
Wonder if someone can give me some advise please.
We are currently in the process of doing our bathroom up and have stumbled across an issue.
Basically, we had to knock down the old plaster board the old owners put up because the tiles were falling off. So, with the new plaster board up and the ceramic tiles on, we are left with an uneven gap from the last tile to the ceiling.
On the shower side, where we have only tiled half the wall, it ranges between 5mm-8mm, this is the worst wall, the other completely tiled wall looks ok.
We don't particularly want to re-do the ceiling if possible and not keen on the idea of coving. What can we do to seal this?
Many Thanks
Tasha
I
Ian
Welcome to TF. I assume you have a full tile up to the ceiling, but the wonky ceiling has created an uneven gap? I won't preach about poor setting out but, in future try to finish up to the ceiling with a cut tile to hide such issues. My suggestions would be to fill the gap with caulk if the tiles are white or, if your tiles are coloured, find a grout that is a close colour match and fill the gap with that. Not perfect solutions but, gets you around the coving/overboarding ceiling if you'd rather not do that.
Hi,
Standard problem, but on this occasion I don't quite understand,
You've reboarded the walls? and the fully tiled side looks ok (5-8mm?)
but you say "where we have only tiled half the wall, it ranges between 5mm-8mm, this is the worst wall, the other completely tiled wall looks ok"
Cut-out and re-board the top part of the wall so that it fits??
Reply to Gap between tiles and ceiling in the bathroom in the Bathroom Tiling Advice area at TilersForums.com
Hi, I have an issue here. My tiler has left a gap between the trim and the wall. No doubt the...
Hi, please looking for some advice, so we had a horrible tiler leave a tiny gap between the...
5K
Hello, we’ve just had a bathroom tiled. A 1.5cm gap is at the top, between the tiles and...
Jay jean
WHOLE BATHROOM REFIT - ALL WALL FULL HEIGHT TILING AND TILED WINDOW LEDGES. ONE SMALL WINDOW &...
Unsolved
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
