Discuss Gap in Marble tiles in the British & UK Tiling Forum area at TilersForums.com.
N
noobtiler
Hi guys
I have 500 x 500 x 18 marble tiles to lay, only 3 sq metres but heres my problem! My client wants no gaps between tiles and wants it to look like a central london banking hall - smooth and flat like glass. How do achieve this? Understand 2 or 3 coats of sealer... But underfloor heating is installed so will this make the marble expand and contract making the no (expansion) gap between the tiles a hindrence? Please help! Wots my smallest gap u say?
Time's Ran Out
Noobtiler - What your client is seeing could well be terrazzo - a form of liquid marble/cement which is 'stoned' flat and polished using wet techniques. It can be fixed in tile sets and grouted tight but again needs finishing with machinery. Both have a weight aspect and are used on solid floors.
What you have are marble tiles onto a potential flexible surface(you don't mention what the substrate is) and with underfloor heating is liable to movement. All tiling requires compressible joints and a such IMO a minimum of 2mm would suffice. Using a colour co-ordinated grout will blend the surface to the reqired 'look'.:thumbsup:
Timeless John.
N
noobtiler
Timeless John.
Thanks John,
my substrate is 18mm ply onto 6 inch joists, which ive had to self lvl with approx 15mm mapei fibreplan (which is very solid) ufh embedded into that with dita matting glued (mapei rv - i think) to the top of the fibreplan. Please dont tell me thats wrong:oops:
N
noobtiler
Noob, the guys are trying to explain to you that a floor grinder/polisher comes in, after the tiles are set and grouted, to grind the floor. This requires specialist (and very expensive) equipment and skill to end up with a mirror like finish.
Thanks oogalbooga, so basically l lay the tiles and if the client wants mirror finished it can be done seperately through other means (specialist)...Thanks again
Time's Ran Out
No the tiles have to be laid as a mirror finish with a nice flush joint.
Have you laid the ditra matting on top of the fibreplan which is ontop of the underfloor heating mats.:oops:
John.
N
noobtiler
John.
I spoke to ditra and the ufh supplier and was told the ufh would still heat thru the compound and the matting to reach the tiles. So its ply, compound with ufh embedded into, ditra matting then tiles....I didnt want to have to self lvl com over ditra then have to do it again over the ufh cables - thought it would have been a mission :yikes:
Reply to Gap in Marble tiles in the British & UK Tiling Forum area at TilersForums.com
Good day all. My daughter has asked me to tile a cooker splashback in her kitchen. They've...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Gap in Marble tiles
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
