Discuss Geometric Floor Tiles in the Best Floor Tiles area at TilersForums.com.
DHTiling
apart from the usaul like prepping of the floor. this type of tiling takes alot of thought and planning well inadvance of fixing. firstly depending on geometric design, plan the borders first, i tend to dry lay these first around the perimeter of the room ( which is usaully hallways ) because the borders have to connect in and around corners etc, taking great care to get them straight , once satisfied they are in correct position then fix borders in situ, allow to set so you dont move them, then depending on infill pattern centre these within borders and when happy with lay out fix these aswell, alot of geometric tiles are of a porous nature and need sealing ( the ones i have laid anyway ) , some patterns are quite easy others are difficult so plan carefully and lay once. hope this helps and post picks when done. dave.
Reply to Geometric Floor Tiles in the Best Floor Tiles area at TilersForums.com
450 x 450 porcelain tiles were laid on the bathroom floor recently. One of the tile sometimes...
Best Floor Tiles
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
