Discuss Getting correct sized mat. in the Canada Tile Advice area at TilersForums.com.
Bubblecraft
I'm a warmup man through & through. Very reliable system. Lifetime guarantee (based on the life of the floor covering) & 3 year warranty on the 3ie stats. Various colours of stat, very modern looking and very easy to use full colour interface.
You are correct about cutting down the wire. The matting it self is cut & flipped to change layout preference. The wire cannot be so be sure to measure accurately. As Bri has mentioned above. Objects should not be placed on top of the UFH other than the floor covering.
Are you looking to use your UFH as a feet treat or as a primary heat source within the room?
Bubblecraft
Thought I'd double check to see if I were going crazy. Sure enough, it's still available. Comes in 4 mat sizes. Good as a low budget warmer.
http://www.**********.co.uk/tprod1290/Feet-Treat-Under-Tile-Warmer-16-25M2.html
I'd still recommend Warmup. Features & benefits of Warmup matting are:
Thinnest wire you can buy: 2mm, multi-strand core, double-insulated using advanced flouropolymers
Sturdy fibreglass mesh for extra durability and super-sticky double-sided tape for secure installation
Quick installation - Simply roll out mat with pre-spaced wire
Flexible - no customizing is necessary
Approvals: ASTA BEAB, KEMA, GS, CERTIF, VDE and CE mark
Lifetime Warranty
SafetyNet Installation Guarantee
Reply to Getting correct sized mat. in the Canada Tile Advice area at TilersForums.com
Dear all, First time poster here and would like you r kind suggetion. I am getting a builder...
Tilers Forums on FB
