gmt1981
Hello all,
Right...the Wife and I have just bought a right old project so funds are low, so I am trying to do what I can wherever possible to save costs. I will get the pro's in to do the tiling and plumbing but would appreciate some help to ensure the job is prepped properly prior to getting them in.
The room in question is an ensuite which was retrofitted using a stud wall set-up. As per the photo below I have installed 6mm backerboard to the floor and 12mm backerboard to part of the alcove where the shower will be situated.
As you can see space is pretty critical even using a 760mm square tray. Much to my frustration, as this is not highlighted anywhere on plumb center or Coram's website, the tray is in fact 775mm wide which has all but removed any chance of dot and dabbing the backerboard onto the solid brick wall.
This leads to my first question - what would be the best way to fix the board to the wall? Perhaps using some marmox washer type fixings or would standard hammer fixings suffice?
Next issue is the upstands...
As the bottom of the coram tray is ever so slightly wider at the bottom than the top, the upstands sit proud of the wall by ca. 6-7mm, meaning at least an adhesive bed of 10mm would be needed for the tiles to lead correctly down onto the upstand. I now know that upstands can (or is that 'should') be recessed into the wall but this is not an option as the backboard is firmly glued at the joins, so can't really be removed without making a right mess.
Looking at the photos below, would you say a tray with upstands is not going to work? Should I take it back and go for a normal style tray, even thought I thought the upstands would offer a belt and braces solution?
Apologies for the epic, but any advise/tips would be gratefully received!
Many thanks in advance
Graham
Graham
