Discuss Gifafloor - Preparation & Adhesive Advice in the Tile Adhesive and Grout Advice area at TilersForums.com.
Hope someone can point me in the right direction for a DIY project.
Refurb of en suite - stripped out all walls and flooring and slowly putting it back together.
Installed UFH using spreader plates over 100mm insulation boards and used Knauf Gifafloor over the joists & plates. Glued joints and screwed to joists, nice and solid with no movement. Already had wet system in other rooms and spare channel on manifold, will hopefully take the chill off the tiles. Radiator on wall for space heating.
All walls put back up (hardie board) and shower tray installed on riser kit (problematic joist positions!).
Ready to tile the floor, but unable to work out what preparation (primer etc) and adhesive is best for the gypsum based Gifafloor. Area is less than 2 square meters, but not wanting to make a mess.
Floor tiles are 600x300 glazed porcelain, also have same size tiles for the walls, but different style.
Was leaning towards Keraflex Easy with Primer G
Any advice appreciated
GIFA floor have their own primer which you should have been made aware of at the time of purchase.
As you quite rightly pointed out, it’s a gypsum based floor, Portland cement and gypsum are not a match made in heaven, therefore priming with the right product is essential.
Ensure that the priming process is 100% correct,
get in touch with their tech help line for full instructions, it’s a great product, and a great choice.
Thank you for taking the time to reply.
Just looked into the Knauf primer, I was not made aware of this when I purchased the boards.
Looks to be exactly what I need, but difficult to obtain. Import from Germany seems to be an option.
I have read comments, on this site, that I should be using the primer suited to the adhesive.
Are there any views on using Mapei Primer L or T or similar?
I can now see why this type of product is not widely used. Seems great, but compatibility with other systems is poor.
Knauf have suggested that I need to tank the floor and that I should follow the system specified by the tanking manufacturer.
This is not a wet room and I did not plan to tank the floor, but I was going to tank the shower area with the Aquaseal kit. I will probably have enough left over to do the floor and it might be the most simple answer.
Glynn
473
LEYLAND
Morning 3fall. Though the Giffa boards are gypsum it is not the same has an anhydrite screed gypsum. The Giffa board is basically "spent gypsum" and as become inert so they do not present the same problems has the anhydrite screed. Tilemaster recommend: Primeplus primer at 3-1 and Magix or Setaflex adhesive.
Reply to Gifafloor - Preparation & Adhesive Advice in the Tile Adhesive and Grout Advice area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
Tile Adhesive Trending Topics
Hertfordshire
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
