Discuss glass border tiles in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Some can be cut on a dry cutter but mostly you have to wet cut them..but not all blades are suitable for glass...do a test cut with water in and if it starts to shell out with in the cut lines then you need a porcelain blade or a glass blade...rubi do a blade called a CVG and is designed specifically for glass but most good quality porcelain blades will cut as well...hope this helps..let us know how you get on...
DHTiling
SIGMAS ALLWAYS CUT GLASS EASILY ........ YOU NEED 24 HOURS BEFORE YOU CAN GROUT THEM UNLESS YOU USE SPACERS.......................:yes:
What difference would using spacers make to the setting time.? youv,e lost me there.
If you want to grout the same day then tile with a rapid setting adhesive (white )
Reply to glass border tiles in the British & UK Tiling Forum area at TilersForums.com
Hi, first timers here... I am tiling my bathrooms and prefer the look & neatness of tiling...
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
glass border tiles
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
