Discuss Glass Resin filled Travertine in the UK Tiling Forum area at TilersForums.com.
Ken Bruty
1,023
Bedford
Guys and Gals,
This is something I have not encountered before as far as restoration is concerned, basically, the walked on areas seem to have lost the wear layer, and the light traffic areas still have the gloss polished finish. (On some of the part worn tiles, the wear layer has a jagged edge like someone has painted glass on to the tile and it's cracked off)
To restore them:-
1. Is there a product to bring the polished surface back. (I doubt this very much)
2. Is it a case of replacing the damaged tiles with new tiles with the wear layer on
3. Does the shiny surface need to be removed from the good tiles with say Twister pads
so as to match the dull ones, and then restored back to shine with wax,gloss sealer etc.etc.. or twister polishing pads.
I'm looking for the most cost effective and least disruptive way to do this, and I daren't try grinding the wear layer off in case it doesn't work properly. Incidentally, where the dull tiles are, where the holes still have the resin filller in, there are shiny spots in those areas.
Would love to know what you reckon.
Ken Bruty
1,023
Bedford
Dave, the products that have been previously used in attempt to revive it, are Fila's products as Topps recommend for this range. After the initial strip back with their tile and stone stripper, polished travertine and marble protector was used to re-seal it (non topical), then polished stone restorer (a kind of wax restorer that requires buffing after application). My gut feeling is that this was a complete waste of time, because, you can see where the glossy layer finishes on the part shiny tiles, there is a jagged edge, which you can feel with your finger nails which is very hard, you can't pick it off at all.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
Just bumping some threads related to cleaning travertine. Not all threads will be current discussion but if you would like to reply with some information, go ahead, it may be valuable to somebody in the future. Tile Cleaning and Tile Restoration Forum
Reply to Glass Resin filled Travertine in the UK Tiling Forum area at TilersForums.com
Hi guys, Please help me. Really having a nightmare here. Just moved into a new house and the...
5K
A long post and not tiling but I hope someone can help, I'm trying to get some decent...
Musivarius
Hi, i have recently laid slate effect porcelain tiles and since grouting the tiles have...
11K
Rizzle from the Portizzle
Hi. I've been asked to restore a travertine kitchen floor. Its a bit grubby and some parts of...
Concrete guy
Ken Bruty
Bedford
What member type are you?
  1. Professional Wall and Floor Tiler
Business Name
KDB Ceramics & Stone
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
