Discuss Glass tiles cracked in kitchen in the Canada Tile Advice area at TilersForums.com.
msg2004
Hello
bought 3mm thich and 200x100mm glass tiles and had fitted in kitchen around June time last year. Had stainless steel tile edging fitted as well that is about 10mm deep. Tiler had to build up tile glue to bring out tiles to meet the trim. initially one tile cracked and few days later another tn few weeks after many more and now nearly all of them especially over hob.
The builder who claims to be insured initially said he would re-do and not once mentioned cost, now wants 2-3 days money to re-do. The supplier of tiles via internet purchase is saying they have sold many thousands of tiles and no problems.
The tile used Bal fixing glue I think. (Got the company that did the kitchen and tiles from Mybuidler and I have not yet left feedback - he's got 100% feedback but las lot was July 2012) (Only about 3 msq of tiles - who much would that cost to re-fit if we took down our-self, ie cost of fitting only is the other option I'm thinking of.
Where do I stand, who is at fault? Also an approx idea re cost of labour for re-tiling approx 3 msq - into window,over hob and one tile high over work surface and metal tile trim.
As you can see I lose out as tile supplier is saying its not him and now the fitter has changed tune and want 2/3 days money - not mentioned how much and won't ask. I feel as though I have been cheated out of several hundred pounds.
(I will leave feedback on MyBuilder after conclusion)
Thank you.
Bubblecraft
Hi. Sorry to hear of your problem. If he has admitted fault & that he is insured, this should be fixed free of charge.
If you could post some pictures up, it would be most helpful.
Unfortunately, My Builder, My Hammer, Rated People etc are a what a con & the sooner customers realise this the better. This says nothing about a builder/contractor/Tiler etc. They pay for the privilege to get your lead...that's it.
You should not be removing the tiles. This should be done by the builder who has wrecked it in the first place. You take the chance of causing further damage by removing the tiles where your builder can say that it is not left in the state that he left it. We also do not discuss prices on the open forum.
msg2004
Hello all
thank you all and will get my son to do pics weekend or soon after.
The 10mm trim used as it looked good.
Yes 3mm tiles are bit to think but was caught out as mother-in-law passed away few days building works to start do bought from the net.
tilers used BAL tubbed, ready prepared glue.
The walls had been skimed.
tiles around boiler pieprs covered by boxing in using ply not split
Most are split by the gas hob.
I feel cheated, the builder I used from MyBuilder was indicating all along he would re-do and never once mentioned costs. He said he is insured, most likely for if the hosue fell down but not mistakes like this.
Re My Builder, don't think they allow negative comments to be posted? I will give this bloke a chance and may even pay some of the money for labour but see how he reacts - he said not his fault, tile supplier says not his fault, and I know it was not my fault
If that was me ie the builder I would have resovled - I think we kept him sweet as we did intend to get more works done, but as costs were more than anticiapted we have delayed, possibly his stance.
Thank you and I will update - the replacement tiles are gloss black 6mm 200x100mm but not glass as have had enough of the problem.
Depending on the manufacturer of the tile there are two things to check - should he have used powdered adhesive instead of ready mix and do the fitting instructions mention a minimum distance from the hob? We wanted a glass splashback and that said it had to be 11cm away from hob. If this was stated but ignored then I would chase the builder. If you bought of the net aren't you covered by your credit card provider?
DHTiling
Hello all
That is what i thought ... wrong tile type for the use required...
Reply to Glass tiles cracked in kitchen in the Canada Tile Advice area at TilersForums.com
Hi everyone, With a kitchen renovation, Mrs choose the white mirror quartz floor tiles from a...
We had our kitchen floor tiled in large plank-style porcelain tiles (90cm x 15cm) about 2 years...
Hi all, I was hoping to get some input/help on this situation. Background: We had 12 x 24"...
In about 2-3 weeks after we got our bathroom fitted we noticed that the grout cracked along one...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
