H
heathmount
Hi
I have previously tiled with ceramic tiles but this is my first foray into the world of glass tiles. I'd be grateful for any tips or advice on what I'm planning to do with regards to cuts.
The tiles I have chosen are Fired Earth, the Liquid Glass range. They are 8mm thick and have a painted back. Being an occasional tiler I have no cutting tools so I plan to buy a Geared Diamond Wheel cutter and glass cutting blade from topps tiles along with a manual cutter for scoring. The idea is then to score the tile on the front and then cut with the wheel.
Topps tiles said to score on both the front and back of the tile whereas the Fired Earth website says to score only the front. I'll chose the website advice over the shop advice but is there reason not to score the back?
Is it necessary to tape the tile once it's been scored? How can I cut down the score line if I've taped over it!?
For L shaped cuts is it necessary to drill out a hole at the corner of the L first? The corners should all be hidden by socket covers so if they're slightly ragged I don't mind.
I've read that some people have problems with the paint chipping off the back of the tile which then can be seen through the glass. Is there a way to stop this happening or is it down to the quality of the tools and the tiles?
Lots of questions I know but I'm grateful for any advice.
thanks
Gordon
thanks
Gordon
