burncross
Hi, got a little job coming up, kitchen splashbacks in 150x75x10 glass wall tiles, Brick bonded.
So a few questions as I'v not used these before.
The customer doesn't want trims to be used around the window or external edges, so i need to get a good cut edge
The tiles are about 10mm thick and will cut on a dry cutter as long as it's in half, but leave's a very sharp edge, is there any type of file available to chamfer the edges?
I'm going to get a glass cutting wheel for my wet cutter, so I don't know yet how it will cut with these? will they chip on the cut edge?
Will BAL whitestar be ok to use, the tiles have a sort of foil backing.
What sort of grout, will these tile scratch with a normal sand based grout?
