JJS1410
Hi,
In my brief tiling career to date I've not installed this type of tile before and I'd like to ask a couple of questions:
1. Cutting - I have a Clinker for dry cuts and at the moment a Plasplugs wet cutter, will these be suitable for cutting this type of tile (it's 9mm thick floor tile)? Do I need to put a porcelain wheel on the wet cutter?
2. They will be tiled into 18mm chipboard flooring (Which is supported off a concrete floor on c50mm thick wood at centres of approx 200mm), is a standard flexi adhesive and grout suitable or do I need to go for a specialist porcelain adhesive?
Thanks in advance for your help/advice
