RDTiling
Hey guys.
I'm going round to look at a friends bathroom and kitchen, as they would like to replace both rooms flooring with tiles. I've not seen the rooms yet, as they have just moved house, however I am led to believe that there are floorboards underneath the current floor coverings in both rooms. These will be my first paid tiling jobs.
The bathroom currently has a carpet on the floor, and they are only looking to replace the flooring but keep the bathroom furniture.
The level of the bath is already set, therefore when I overply the floors, this will raise the floor level and then tiling on top of this will raise the level again.
Also, they have asked me to regrout their walls tiles, just to freshen them up a bit. Without discussing actual prices as we are in the open forum, would you charge a metre square rate or a half day/ day rate to regrout? If it is a metre square rate would something like 25% of your metre square to lay tiles be acceptable?
Is acceptable to simply tile the floor to where the bath panel meets the floor, or would you guys tile slightly under the bath and trim the height of the bath panel to sit on top of the tiles (assuming this can be done).
The kitchen has lino down at the moment. I guess my question with the kitchen is similar to the bathroom in that can I just tile floor to where the edge of the appliances are, or is it better practice to remove the appliances tile all the way to the walls and then put the appliances back in on top of the tiles?
Many thanks guys,
Rich
Many thanks guys,
Rich
