U
Unregistered
Hi everyone,
have looked at many posts but cannot seem to find the answers I require,so thought I'd post.
I am in the process of completely updating our bathroom,new shower cubicle,new rads,new ceiling,floor & wall tiles,etc.
I understand about walls being out,putting battens on wall & putting cuts into corners,& basically choosing the best compromise ,as you cannot get everything you want when you retile a room.
Basically when you look at a finished tiled room,should all the tiles & vertical grout lines be exactly opposite on the other wall?
I 've tiled to adjacent walls ,with a half tile cut in both corners,in the other untiled corner we are putting a quadrant shower cubicle ,now i wanted to use full tiles from the shower cubicle corner working outwards,one side to a doorway,but along the other wall,this would mean that tiles on opposite walls do not line up.
Should I match the opposite tiles/grout lines up parallel & then accept that I will end up with cut tiles in the corner of the shower.
Regards
Regards
