john56897452
So fitted Quartz starstone floor tiles. Used Mapei super flexible UFH compatible adhesive on screwed and glued 6mm Hardie backer board. Finished with Granfix maxigrout flexible grout.
Floor area about 1.3msq so smallish. I checked with the supplier (Tile choice ) and tiles ok for 150 watt UFH. Turns out I have fitted 300w warmup loose wire. Not switched on at all yet or commissioned. Has quartz tile technology come on enough yet or is my floor doomed?
I may add I have no intention of using full heat just maybe 20 degrees or so to take the chill off the tiles in cold weather. Main heating in this small en suite is a radiator. Any expert advice on my options beside the obvious of don't switch on.
