Discuss Grade A Fire Detection Advice/Installer Required Electrical Advice in the Electrical Advice area at TilersForums.com.
Grade A Fire Detection Advice/Installer Required Discussion ThreadGrade A Fire Detection Advice/Installer Required Electrical Advice
In my 3 storey house I need to fit a grade A LD2 alarm system. Mains connected grade D currently exists in the correct locations but I guess because they are not fed by FP cable I will need to rewire to the new detectors I'll need to purchase, which I am capable of doing.
What I can't do is connect it all up to the control panel and the control panel to the consumer unit. I will also need a certificate. For this I would hire someone.
Questions:
Does the above sound like a reasonable way of lowering labour costs that an electrician can work with?
Does all FP cable need to be enclosed in trunking (even if inside a cupboard or in the loft)?
Is the interlink cable separate?
Any advice for how to get this sorted as low cost as possible? Happy to receive quotes (NW London).
Grade A Fire Detection Advice/Installer Required for the original thread on Electricians Forums
Reply to Grade A Fire Detection Advice/Installer Required Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
