Discuss granfix maxi grout (charcoal)discolouring in the UK Tiling Forum area at TilersForums.com.
Sean Kelly
1,068
Ruislip
I've got the same problem with Granfix maxigrout brown. I used clean water and washboy. Got the call yesterday from the customer to say that the grout has gone a funny colour. The man at Tile Depot tried to sell him a cleaner to clear up efflorescence. This is the first time I have used Granfix grout. I believe that the BAL Microcolour reduces the chances of efflorescence. I will try and sort out this issue this week.
Sean Kelly
1,068
Ruislip
I tried to clean with 'cement away', but the grout is getting whiter. I have scrubbed away with scotch pads, but the problem is getting worse. I would have thought that efflorescence would come away with a bit of scraping, but this is not the case with this situation. I noticed yesteray that the bag of grout has a date of Jan'10. It states that it should be used within 12 months of this date. The date is so smudged on the bag that it was very difficult to read. The grout was only bought last week by the customer. The customer is bringing the bag back to Tile Depot. I also noticed that the unused mixed grout that I threw away is not actually brown in colour. It has a uniform silver/white/dusty colour. So could this be down to the fact that the grout is old?
Sean Kelly
1,068
Ruislip
The area is only 1.5sqm. So I only mixed a small amount of grout. I normally use BAL grout, but recently customers have been getting their own grout. I did 30sqm of floor a few weeks back and used an Italian grout. I mixed it to the letter (used a measuring jug for water). It turned out so dry I had difficulty working with it. I have never used Granfix grout, but it did state only to mix enough for 20mins work! Good job I was not doing a big floor area, as I'm pretty sure there would definitely be colour variation in the grout. So if anything, I may have slightly (only slightly) mixed the grout a little on the wet side. I used a well squeezed out sponge to wipe off excess grout. If I don't have any luck with the vinegar do you think I could just paint on Aquamix colourant?
jay
is that the grout pens .That would be your best option . Recommend you find a grout you feel comfortable using and stick to it .That way you are not dealing with different brands and problems just supply your own and ask customers to return what they purchase . grout can make or break a good job
Sean Kelly
1,068
Ruislip
Aquamix colourant comes in a bottle. It is applied with a toothbrush. I have used it before, but did not know if it would work on this discoloured grout. Am I thinking that this whiteness is not efflorescence? You are quite right about sticking to one brand. Cheers Sean
Sean Kelly
1,068
Ruislip
Reply to granfix maxi grout (charcoal)discolouring in the UK Tiling Forum area at TilersForums.com
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
