groucho
Hi all, well got a small floor to do with granite tiles. Is there anything i need to know? going to use x7r addy. I presume wet saw all thw way? sealer?
thanks
thanks
Discuss granite in the British & UK Tiling Forum area at TilersForums.com.
Floor need to be flat as Kev said. Is it screed or timber? Heated or unheated? and yes wet saw all the way. Seal with something like Lithofin Stainstop MN.Hi all, well got a small floor to do with granite tiles. Is there anything i need to know? going to use x7r addy. I presume wet saw all thw way? sealer?
thanks
Concrete floor, screeded with Granite tile.
1.Prime ( not PVA ),
2.Set tiles with single part or rapid flexible,
3.Seal Granite with recommended product,
4.Grout with flexible grout
NB. On larger areas, some form of movement joint may be required. as outlined in British Standard BS 5385: Part3:1989:Clauses 19 and 23.6
Sorry Adam, just for you then mate, in brief......Don't be so vague Gaz :lol:
4.Grout with flexible adhesive.
Reply to granite in the British & UK Tiling Forum area at TilersForums.com
