Discuss Granny charge point Electrical Advice in the Electrical Advice area at TilersForums.com.
Granny charge point Discussion ThreadGranny charge point Electrical Advice
I'll start by saying I don't install EV chargers and have not kept up to any great extent on regs changes etc but an existing customer has asked for a 13a socket for her EV granny charger in a 2nd home. (the previous outdoor socket has melted!).
After doing a bit of reading including 722 I have come to the conclusion that providing a 13a socket for such dedicated use is pretty much pointless as complying with all requirements would be too onerous..(I'm assuming here that the granny charger itself does not contain RCD-DD or PEN fault circuitry).
Am I correct here? or do any of you seasoned EV installers have a work around?
So far I have advised the customer to seek quotes for a 'proper' charge point but I wonder if in fact they will just replace the outside socket and carry on until the next one melts etc etc as of course there is nothing to stop anyone plugging a granny charger into any socket they like.
Granny charge point for the original thread on Electricians Forums
Reply to Granny charge point Electrical Advice in the Electrical Advice area at TilersForums.com
Plazma cutter causing SPD failure?? Discussion ThreadPlazma cutter causing SPD failure...
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
