F
frogeye
Hi
The shower tray simple installation I went to 3 days ago has turned into a major refit.
The tiling is poor to say the least, but well fixed - so can I dot and dab the green plasterboard onto the existing tiles and if so with what do you recommend? I assume there will be no need to roughen up the tiles?
Floor is coming up to be replaced - going for a bamboo floor.
Will cut access hatch into ceiling below (its out of the way) to enable easy fitting and access to shower tray and in case of problems - also allows the service valve for the shower to be relocated as it looks crap where it is on the surface
Will have to relocate a cold supply as it's in the way of the shower tray.
Half tiles to dado and plastered or papered above. Is there a company that does the plasterboard with a tapered edge so that skimming isn't required?
Would you use the green stuff for the bathroom or normal?
Will tank the shower area to be on the safe side
Any thoughts?
Cheers
Any thoughts?
Cheers
