Discuss Grey grout cleaning in the UK Tiling Forum area at TilersForums.com.
Hull
Hi all would appreciate some advice on how/when you clean your grey grout off black tiles. when I have started cleaning off grout in the past and present job the residue takes some getting off the tile. I leave the grout for the required setting time before cleaning off a few times. Is it best to then wait for the grout to fully set then clean remainder the following day ? how do you all approach this problem. I have tried both sponge and washboys. thanks in advance
Rich
Best advice I can give is to work clean from start to finish. When grouting, take off as much grout off the face of the tile with your grout float, then leave it to set off just enough. To long and you will have to scub it away and to soon and you will pull the grout out of the joints. When wasing off, use clean water and a clean sponge and rinse the sponge out as often as poss. If you need to, keep changing your water for clean stuff and wash off more than once if it is still a pig to clean.
Reply to Grey grout cleaning in the UK Tiling Forum area at TilersForums.com
Hull
Grey grout cleaning
