Discuss grinding porcelain in the British & UK Tiling Forum area at TilersForums.com.
Pencil
Hi all,
I have a client who wants to have 3 large curved steps in polished porcelain but wants the front edge exposed .
So i made a order for a new Fein WSG 14-70 ET on there recommendation but i cant help but feel its not gonna be sufficient and am looking to see what you guys think on wether or not i should go with the dry polisher or spend a little more and get a wet machine if so what would you recommend.
Is a dry machine going be able to sand it enough for me to work to a template?
I have tried to steer the client away from having the edge exposed for obvious reasons but no joy
Thanks in advance
Pencil
What finish are you trying to create? A half bull nose/pencil edge or square polished?
I assume we're talking about a tile circa 8mm to 10mm in thickness?
They are 10mm thickness and its only a square edge finish , you think i would need to have to purchase a GTR30 as well then to get the initial edge ?
Then polish it up with the fein with a flexible pad and paper ?
I was planning on getting it as close to a final shape with just nippers and wetcuts then using the fein to sand / polish it up but im assuming now thats not going to be enough to do the job.
Concrete guy
Your best bet is buying a dished blade that will cut curves, then cut as close to your finished line as possible.
Then a hard backer pad with Silicon carbide pads should get you the finish you need. You don't really want a flexible pad for external curves.
An easier method may actually be to mark them up, drop them into a stonemason or monumental mason and get them to cut/polish them for you.
Pencil
Ok the dish blade i can use on my wetcutter np but would i need a wet polishes/grinder for the Silicon pads or is the WSG 14-70 ET (dry) sufficent with the correct pads etc?
I am worried about chipping and having to replace many tiles from chipping.
Peter
Here's pictures:
Cut as close to the template as possible with a grinder blade held as flat as possible, then GTR30 finished any indiscrepencies. Resin pads sorted out the sides, although wasn't full bodied porc so could only polish the top glaze.
Pencil
Thanks guys for all your advice and sorry for taking so long to reply.
Ive also posted some images of the final finish ;) pretty chuffed tbh
There is one more thing mind i found that the bottom of the tile would chip out when cutting with the curved blade, i was laying tile on tile for all my cutting but could not seem to get a complete clean cut in some places.
It was not massivley noticeable but still i could see them
Any other ides on stopping this from happening ?
Anyway thanks again was a great help and shame my phone camera was so poor for the before photos.
erS0k7jAwc4de__p-TNA3eKFb_2ihgpeyunhp_p6KkQ.jpg OKyY6fHHLlMEykAJZuXZUw14_QjqZmmKT2bi9R2K3vY.jpg Z9RSIEZ4qyu6WzFb3CNQbc0ecnqj63tjAgwB9CPBZ8A.jpg
charlie1
Method i used was:
1, Dry lay tiles
2, Tape area and mark line (use template or whatever)
3, Make one continuis pass using angle grinder and good blade (about 1mm deep)
4, Remove each tile then make several passes till tile is cut
5, Dress edge and set.
6, Once all tiles are set, give another final dressing using small diamond hand pad.
No need for any fancy tools, just a grinder and a diamond pad and you can achive a factory finish.
View attachment 49567 View attachment 49568 View attachment 49569
Just one thing notice in your second photo is that a horrible bag of Toppfix ? evil stuff,best place for that is in the bin. :bigcry:Apart from that nice job :thumbsup:
Reply to grinding porcelain in the British & UK Tiling Forum area at TilersForums.com
I have been researching this for days and need some help. My garage has a concrete floor. I live...
My client is wanting a loft floor tiled with 600x600 polished porcelain tiles. Hes building a...
Hi all Just joined the forum, have visited many times before ,when I needed advice and...
Perfect Tiling
Can anybody recommend a cutter that will produce very good edge cuts on 10mm very hard porcelain...
9K
Hi All, I urgently need some advice and not sure where to turn. We are having some major...
6K
Rookery
grinding porcelain
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
