Discuss Grommets and 10mm Hollow Threaded Tube Electrical Advice in the Electrical Advice area at TilersForums.com.
Grommets and 10mm Hollow Threaded Tube Discussion ThreadGrommets and 10mm Hollow Threaded Tube Electrical Advice
Hello everyone,
I'm currently making a table lamp out of driftwood found on the beach.
Does anybody have any ideas about the cable passing through the 10mm threaded rod regarding grommets.
I'm wondering whether I should use 3/8 BSP to 15mm plumbing connection to get me into a wider diameter.
Rope cable is rated at 700w so the bulb will be nowhere near that amount.
Any help here would be greatly appreciated!
I've attached some pics and thanks in advance.
[ElectriciansForums.net] Grommets and 10mm Hollow Threaded Tube
Grommets and 10mm Hollow Threaded Tube for the original thread on Electricians Forums
Reply to Grommets and 10mm Hollow Threaded Tube Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
