Discuss grout degrading in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
A tile grout that is not fully water proof will let water seep into it..this is normal for grouts..( unless an epoxy one is used ) The grout does wet up but unless there is excessive wetting then it is not usually a problem as long the the prep work to the substrate is correct... as for damp and mildew degrading then i would say no!! ...
If you have problems with a crumbly grout etc...then it is more likely to be a poor installation or wrong grout was used for the job....
Reply to grout degrading in the British & UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The...
grout degrading
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
