Discuss Grout film remover in the UK Tiling Forum area at TilersForums.com.
DHTiling
Pack Size: 1 Litre
LTP Grout Stain Remover
Description: LTP Grout Stain Remover is the solution for removal of cement and grout residues and is extremely effective against mineral salt formations (efflorescence). Useful for routine cleaning of patios and other outside paved areas, LTP Grout Stain Remover may be used on glazed ceramics, quarry tiles, terracotta and some stone.
Tips: Pick this product if you have cement and grout residues, mineral salt formations, limescale, water marks, dirty patios and other outside areas. Do not use on limestone or when underfloor heating systems are in operation. DO NOT USE ON ACID SENSITIVE SURFACES.
Technical Data Sheet (PDF)
Reply to Grout film remover in the UK Tiling Forum area at TilersForums.com
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The...
Unfortunately the tiler did not follow the manufactures instructions for mixing up the two part...
Tilers Forums on FB
