Discuss grout gap/ porcelain tolerances in the Canada Tile Advice area at TilersForums.com.
dancn
I'm about to buy and lay some porcelain 600X600.I like the look of the cut edge with a tight grout gap. I looked at some recently and and checked the the tile tolerance from the packaging +/+0.5mm.
So if these are rectified and a 1mm grout gap is required then grading of the tiles will be required right? (50m2)
Is achieving a good result going to a lot of pain, with such a tight grout gap( floor is flat)
Yeah, 3mm but don't sone state that on the packaging. I've went to 2mm only to be caught out by the dimensional variations. Veiry few work out perfect at 2mm but I suppose that's why some of us do this for a living :) I do meet clients and they have given a job elsewhere cos I've refused to butt them tight or even use 1mm spacing. They know best I suppose ;)
dancn
perimeter expansion i can acheive 10mm , in places up to 25mm.
I have the time and space to grade the tile widths so I think this would be help.
2mm looking more realistic then.
My thinking was the whole tiled area as a slab would need movement, hence perimeter gaps, or metal joints.
So the theory behind the wider grout gap is that the grout gaps will compress/contract, is there a special grout that can cope with this.?
going for creamy tile/grey grout hence trying to minimise the gap.
Rossymcg
youre asking questions that would suggest you need to get someone in who knows what they're doing, you may end up with 50m2 of a mess,
Rossymcg
how does asking questions suggest I need to get someone in?
how would you tackle it?
Answer to Q1) if you're asking questions with basic answers (ie 1mm grout lines on a floor) to me indicates you don't know what you're doing,
answer to Q2) very much dependant on other factors but off the cuff with out seeing the job, I'd self level it, but drift it in to the raised area in a very gradual slope also self leveling on top of the raised area so you don't get a platform to have to tile on to, but it doesn't end there with that because I'd then have to pick up and drop tiles using different thickness of addy beds, polished porcelain 2ftx2ft ain't the easiest of tiles to lay and you've increased the difficulty even further,
Reply to grout gap/ porcelain tolerances in the Canada Tile Advice area at TilersForums.com
Hi there Homeowner here who recently had my kitchen tiled by a professional tiler. We’ve been...
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
We recently finished a bathroom renovation where the two builders who did the bathroom also did...
Evening all! We recently had our bathroom renovated, the Plumber/Tiler we hired to do it was a...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
